set env variable : HOUDINI_PATH does not work.
   2134   1   0
I'm working in Unity trying to launch Houdini with the HOUDINI_PATH and HOUDINI_PACKAGE_DIR value set,I wrote c# code to set the env variable before launching Houdini,but after the setting,Houdini can't be open,
so,I am trying to set it in the computer,not by code, just to check out why Houdini can't open,
and now,if I add HOUDINI_PATH with value like C:\a\b\c ,it shows error:
ERROR: Couldn't open resource file "resources" (No such file or directory)
= = = Houdini Package log = = =
Loading: C:/PROGRA~1/SIDEEF~1/HOUDIN~1.531/packages/kinefx.json
Loading: C:/PROGRA~1/SIDEEF~1/HOUDIN~1.531/packages/package_dirs.json
: Undefined variable ${HOUDINI_DISABLE_SIDEFX_PACKAGES} used in expression ${HOUDINI_DISABLE_SIDEFX_PACKAGES} == '1'
WARNING: Unsupported value for enable
Processing: C:/PROGRA~1/SIDEEF~1/HOUDIN~1.531/packages/kinefx.json
Processing: C:/PROGRA~1/SIDEEF~1/HOUDIN~1.531/packages/package_dirs.json
Resolved variables:
HOUDINI_PATH :
C:/a/b/c
WARNING: Found hotkey for context 'h.pane.parms' before the context definition
WARNING: Found hotkey for context 'h' before the context definition
Error running event handler:
File "kinefx::Sop/adapttoterrain, opdef:/kinefx::Sop/adapttoterrain?ViewerStateInstall", line 1, in <module>
File "C:\PROGRA~1\SIDEEF~1\HOUDIN~1.531\python37\lib\site-packages-forced\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import
return original_import(name, *args, **kwargs)
ModuleNotFoundError: No module named 'viewerstate'
File "kinefx::Sop/scenecharacterimport, opdef:/kinefx::Sop/scenecharacterimport?ViewerStateInstall", line 1, in <module>
Could not initialize the help server:
File "<stdin>", line 1, in <module>
ModuleNotFoundError: No module named 'houdinihelp'
ERROR: Couldn't find 'FUSE_ColorOptions.ui' for reading. Looked in:
C:/PROGRA~1/SIDEEF~1/HOUDIN~1.531/packages/kinefx/config/Applications
C:/a/b/c/config/Applications
and if I add HODUINI_PACKAGE_DIR with value like :C:\a\b\c\package ,Houdini does not appear at all.
anyone can help to tell what is the standard about it.
thanks.
Edited by pengzhang - Oct. 27, 2022 22:27:38
In linux you can source houdini_setup and use $HH
(or anny other houdini environment variables)
In windows you cant use HCMD to launch Unity.
https://www.sidefx.com/faq/question/how-do-i-set-up-the-houdini-environment-for-command-line-tools/ [www.sidefx.com]
I`m not sure this is what you are trying to achieve.
