Anyone able to make Quixel Bridge work with Houdini 19.5? I've downloaded their plug in, but it seems to only install / support Houdini 19?
Luke
Quixel Bridge with Houdini 19.5?
10301 8 2- LukeP
- 374 posts
- wanglifu
- 187 posts
- LukeP
- 374 posts
- RudiNieuwenhuis
- 193 posts
- LukeP
- 374 posts
RudiNieuwenhuisLukePwanglifuI did, but when I export I get an error.
just copy MegascansPlugin.json file into houdini19.5/packages folder.
If you specify the error, chances of finding a solution tend to increase.
My apologies. It seems to work fine now! No idea what it was, but it exports fine.
Thank you for the help!
- LukeP
- 374 posts
LukePLooks like I spoke a bit too soon. So, with 19.5 everything seems to be loading fine from a geometry perspective, but materials do not appear to display on the objects.RudiNieuwenhuisLukePwanglifuI did, but when I export I get an error.
- LukeP
- 374 posts
LukePSeems like the reason is that textures in the material have .rat extension, but are downloaded as .jpg. Changing the extension appears to be fixing the issue.LukePLooks like I spoke a bit too soon. So, with 19.5 everything seems to be loading fine from a geometry perspective, but materials do not appear to display on the objects.RudiNieuwenhuisLukePwanglifuI did, but when I export I get an error.
- dinjia2008
- 2 posts
- Nikyone
- 10 posts
