Alembic Geometry behaving different in C4D
   Views 1177   Replies 1   Subscribers 2
No matter what I try, this alembic just won't export properly to C4D. When I re-import it into Houdini it displays perfectly, the streaks reach their target and disappear.
However, within C4D they just stay put and nothing happens. Any ideas?
You can see that only the first two behave this way, also there is this weird shape in the beginning that should only appear when the spears start firing. Houdini does all the right things but not sure how to export it correctly?
Edited by sususk - Dec. 2, 2022 05:57:47
alembic-test.abc (14.2 MB)
asdf.mov (59.9 KB)
hi
I just imported the abc in 3dsMax and it behave the same
but it behaves not only on the the first two - also on later Frames (but only a few Frames)
from my experience in Max there have to be a polygon
- so I think when there is no polygon in the abc the last polys are shown
you can try to scale them down to zero at the end
