Is there any way of merging heightfield masks?
   3512   5   2
I just have a number of very contrasting heightmaps that are made up of single slightly blurred lines that make up what are supposed to be rivers - I would like to merge them together if that's possible, I've used 'Heightfield_MaskExpand" but it only takes two inputs, and I'm sure that's not what it's for.
This is what they look like:
Screenshot 2022-12-15 131809.png (382.8 KB)
A "mask" is just a single 2D volume primitive with a name.
You could use an attribute wrangle to give each mask a unique name.
if(s@name=="mask"){s@name="mask_01";}
Then you can use a heightfield_combinelayers to add in multiple masks that get written out to a new volume named "mask".
Check the help card on combine layers.
There are probably other ways to do this as well...
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
Thanks I'll give that a go, most of this is in VEX anyway
Isn't a mask just a grayscale bitmap applied to a plane though? That's why I thought it would be easy to combine them.
Edited by DavidB - Dec. 15, 2022 10:03:08
DavidB
Kind of but it's in voxel form. You should also be able to combine them in a volume combine with 'maximum' operation.
It's probably a bit late, but I figured out a nice way to merge masks. Using an HF Insert Mask node from Labs, you can add mask layers with custom names quite easily into height fields, and then using an HF Combine Masks node mix them together to get what you want.
Hopefully this will be helpful for someone
WinterLight
Thank u so much, i was looking for this so long, glad that i found your post about this!
Much love )
