Hello guys,
need help with a conditional inside switch node.
I have a wall , sometimes with odd number of prims (3,5,7..) and other times pairs numbers (2,4,6..).
Depending that number the switcher must select the correct one (0 or 1).
I need the wall divisions to be CENTERED in the wall. With de RESAMPLE node it seems imposible.
¿¿What is the correct code to apply??
should something like this:
if(nprims('../reverse5')==0, 0, 1)
Thanks in advance.
Divide>Bricker .. switch if ODDS/PAIRS
1645 4 1- bhb
- 67 posts
- Jikian
- 144 posts
- bhb
- 67 posts
- tamte
- 8853 posts
bhbilbaoSounds like you want
nprims('../reverse5')%2
You may need to swap your inputs as even numbers will return 0 and odd ones 1
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- bhb
- 67 posts
