boneCapture attribute rename joints.
   2234   5   0
I'm creating a bone renamer using the Multiparm list. I am stuck in the rest geometry 'boneCapture' attr. The attribute type is 'Capture' I have never faced an unknown attr type.
boneCapture_ask.hip (697.6 KB)
you can use Capture Attribute Unpack node to extract array attributes from it, process and Capture Attribute Pack
you can also just use Attribute String Edit to directly on that geo rename the capture region names using multiparm without unpacking
Edited by tamte - Jan. 19, 2023 16:12:33
FX Supervisor
Method Studios, NY
Thank you for replying. I used Attribute String Edit. I chose a class and attribute. From: Root_M To pelvis. but nothing happens.
Hastur
that's definitely curious
I tried and it works if you don't specify attribute
and also if you specify the name as: boneCapture*
not sure why, but seems to work
FX Supervisor
Method Studios, NY
This is awesome Tamte. Thanks for sharing, this is real time saver.
Edited by willh - Jan. 26, 2023 01:51:34
tamte
Hastur
Indeed! thanks for sharing!
