adding info to the null / a extra node
   1283   2   1
For alot of years Im using houdini now....
We always using expressions like bbox, centroid,etc...
Wouldnt be nice to have a node that has this data available in a node?
to refference copy to other nodes instead of typing the code every single day?
I created them alot as preffs. but they somehow always dissapear on updates or new versions.
$OS in group-names.... they even cant be saved anymore by default (user preff... or others)
because its not working anymore after I guess 18.5...?
(but thats another problem)
Im sorry to place this in a group thats not the one to use...
but I couldnt find any other related group...
Its technical.... and I guess also a discussion???
what do other people like to see?
cheers!
Edited by dennisvolkerts - Jan. 30, 2023 11:25:31
Make a HDA? You can save expressions as "default value".
I've been thinking about creating some right-click menu items that can create parameters like this on demand, but haven't gotten around to it.
Btw it may be disappearing when you update to a new version of houdini because the presets folder is in the My Documents/houdiniXX.X folder. So if you went from houdini19.0 to houdini19.5 you would need to copy the presets folder to the new houdini folder.
Alternatively, you can store presets in packages folders which is something I want to detail in a tutorial pretty soon because it's not really well documented... if at all.
Houdini TD, I focus on tools for procedural asset creation.
www.jaworenko.design
