[SOLVED] Consistent crash on Ubuntu 22.04
   4916   13   3
I installed 19.5.435 on Ubuntu 22.04, but it is crashing constantly.
I ran `source houdini_setup_bash`, added also `/lib/x86_64-linux-gnu` to LD_LIBRARY_PATH (since I needed this on another Ubuntu machine). But none of this helped. Any ideas? It seems to segfault quite early in the process.
Crash report from bottleship; Houdini Core Version 19.5.435 [linux-x86_64-gcc9.3]
Uptime 1 seconds
Wed Feb  1 16:19:28 2023
Caught signal 11
Traceback from 1182530 ThreadId=0x7fd695823e80
AP_Interface::coreDumpChaser(UTsignalHandlerArg) <libHoudiniUI.so>
AP_Interface::si_CrashHandler::chaser(UTsignalHandlerArg) <libHoudiniUI.so>
signalCallback(UTsignalHandlerArg) <libHoudiniUT.so>
UT_Signal::UT_ComboSignalHandler::operator()(int, siginfo_t*, void*) const <libHoudiniUT.so>
UT_Signal::processSignal(int, siginfo_t*, void*) <libHoudiniUT.so>
__sigaction <libc.so.6>
Edited by monomon - Feb. 3, 2023 06:22:23
Unfortunately that stack trace doesn't provide any information on what exactly went wrong. Have you tried without setting LD_LIBRARY_PATH?
Thanks for the response, yes I tried all kinds of permutations of sourcing the setup script, setting env vars and not.
I realize this stack is very short and shows almost nothing. Could it be caused by missing libraries? Any way to validate this?
You could try this.
sudo apt install gdb
gdb houdini
Then, in gdb, once you get the (gdb)prompt, type run.
Once it crashes, type: thread apply all bt
Copy and paste all of the output from when you started gdb to the output of the previous command and attach it here. Hopefully it will give us a clue.
Weird, there is almost nothing in this trace. Could it be that the installed video drivers are not the right ones?
Starting program: /opt/hfs19.5.435/bin/houdinicore-bin
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
[Detaching after fork from child process 2240132]
[Inferior 1 (process 2240076) exited normally]
(gdb) No OpenCL platform has the specified device type (HOUDINI_OCL_DEVICETYPE): GPU.
Falling back to built-in CPU OpenCL driver (see HOUDINI_USE_HFS_OCL)
2240132: Fatal error: Segmentation fault (sent by pid 0)
Crash log saved to /tmp/houdini_temp/crash.untitled.bottleship_2240132_log.txt
thread apply all bt
Changed the library path a bit
LD_LIBRARY_PATH="/lib/x86_64-linux-gnu:/opt/hfs19.5/dsolib:/opt/hfs19.5/python/lib" LD_PRELOAD="/lib/x86_64-linux-gnu/libc_malloc_debug.so.0" /opt/hfs19.5/bin/houdinicore
And now I am getting
/opt/hfs19.5/bin/houdinicore-bin: symbol lookup error: /opt/hfs19.5/dsolib/libHoudiniUI.so: undefined symbol: _ZnwmSt11align_val_t, version Qt_5
Is this related to the gcc version that libQt* were compiled with?
Here is ldd /opt/hfs19.5/dsolib/libHoudiniUI.so
Edit: btw I also tried removing the Qt libraries and using the system ones, but then I get other missing symbols.
Edited by monomon - Feb. 3, 2023 04:02:22
houdini-ui-ldd (9.7 KB)
Turned out the nvidia driver was not being used. After configuring it, it worked.
I'm glad you figured it out. fyi, adding /lib/x86_64-linux-gnu/libc_malloc_debug.so.0 to your LD_PRELOAD is no longer needed as of 19.0.594 and will greatly reduce performance.
Oh cool thanks. Is a vendored libc being used?
No, we fixed the underlying compatibility issue with glibc 2.34+.
johnmather
I having the same issue with 19.5.773 ubuntu 22 latest crash at the starting
error: Crash report from raj; Houdini FX Version 19.5.773
Uptime 5 seconds
Fri Nov 3 19:55:01 2023
Caught signal 11
Traceback from 3279 ThreadId=0x7fd989b88e80
You could try this in a Terminal window:
cd /opt/hfs19.5 # or wherever you installed houdini
houdini -foreground
Do you get the same OpenCL errors as OP in the terminal?
Edited by edward - Nov. 3, 2023 22:45:54
edward
houdini -foreground
I able to fix by installing amd graphics drivers from the following link https://support.zivid.com/en/latest/getting-started/software-installation/gpu/install-opencl-drivers-ubuntu.html [support.zivid.com]
