ffmpeg on Mac 19.5
   Views 2296   Replies 6   Subscribers 2
Does ffmpeg work on flipbook export in Houdini 19.5 Mac?
I can't seem to get it working despite it showing up fine in terminal.
In ENV variable I've added: FFMPEG_PATH = "/usr/local/bin/ffmpeg"
Let me know if you got it working on Mac?
I think you need both FFmpeg and ImageMagick for it to work not sure though as I`m on linux.
Same problem but with ImageMagick.
Both ffmpeg and magick are broken on macos, I’ve submitted a RFE, just before stumbling on to this post
levberry
Actually you should link it to $PATH and just the bin dir, and not the binary, think it’s the same for FFMPEG_PATH, so FFMPEG_PATH = "/usr/local/bin" according to the docs...
It has been logged as a bug.
ffmpeg is unsupported on a macos for movie export from mplay, dunno about pdg, dnt, should work?
