Hi.
I am planning on teaching a few layout things in Solaris on Monday. I have made an object with variants of a blue box and a redish sphere.
I am trying to scatter them using the: layout LOP, Copy to points LOP and the Instancer LOP. Just to show three ways to work on layout.
I know I am really close, but I am not able to get the explore instance to randomly switch between the two shapes correctly on any of the three examples. Has anyone go this to work? I have been Googling and found some answers but not all. Thanks in advance!
Best
Mark
Solaris getting explorevariants to randomize instances
2164 3 3- Mark Wallman
- 700 posts
- npetit
- 413 posts
The instancer LOP emits a warning message
If you add a Configure Layer LOP after the explore variants, set it to flatten input stage, your instancing of the variants will work as expected.
Primitive is embedded in a composition arc: /explorevariants1/shapes/geo_box_mtl_componentmaterial3
It would be necessary to flatten the stage to access it.
- Mark Wallman
- 700 posts
- mrCatfish
- 734 posts
Note that this flattens the stage, which means your USD files get huge, amongst other things. Here is a better approach: https://www.sidefx.com/forum/topic/94812/ [www.sidefx.com]
Sean Lewkiw
Machine FX - Cinesite MTL
