SideFX Labs Bugs and issues
   3183   5   1
Here are a couple of Labs Bugs/Errors I stumbled on in the last weeks.
Wasn't sure where to post this.
the Labs File Cache node generates this syntax warning:
labs::Sop/filecache::2.0, PythonModule:240: SyntaxWarning: "is not" with a literal. Did you mean "!="?
labs::Sop/filecache::2.0, PythonModule:460: SyntaxWarning: "is not" with a literal. Did you mean "!="?
labs::Top/topfilecache::2.0, PythonModule:107: SyntaxWarning: "is not" with a literal. Did you mean "!="?
the Labs UV visualize "view in worldspace" does not work, it scales to zero and nothing is visible
the Labs Quick Material generates this error, when switched to Labs PBR Shader:
LINK[/obj/geo1/quickmaterial1/matnet/labspbrshader]:
Fragment info
0(696) : error C3002: call to undefined function "void HOUassignOutputs(vec3, vec3, vec3, vec3, vec3, vec3, float, float, float, float, float, float, float, float, vec4, vec3, float, float, int, int);"
/obj/geo1/quickmaterial1/matnet/labspbrshader: Linking failed.
Edited by chf - Feb. 20, 2023 04:03:52
I get the same or similar error with the Labs File Cache:
Edited by javigarrido - March 23, 2023 16:44:49
This was fixed in 19.5.563.
Getting this error for all Labs Quickmaterials in 19.5.569 when opening a scene file:
Problem while synchronizing child node:
Warning: Skipping unrecognized parameter "diffuse_folder_15"
Skipping unrecognized parameter "folder7".
Skipping unrecognized parameter "folder4".
Skipping unrecognized parameter "folder12 ".
Skipping unrecognized parameter "shading_16".
Skipping unrecognized parameter "folder14".
Skipping unrecognized parameter "folder9".
Skipping unrecognized parameter "folder13
[obj/geo/quickmaterial1/matnet/labspbrshaderl
Edited by JesseR - April 26, 2023 21:55:06
johnmather
Still getting this error in 19.5.569
created new labpbrshader node, no errors, moment I connect/add file texture I get this.
Seems to work fine despite the errors.
