The Houdini Engine for Maya plugin could not be initialized
   Views 8976   Replies 6   Subscribers 1
Hello I have some trouble using the Maya plugin in win10.
I am trying to use Maya plugin for Houdini19.5.493. I followed the instrusions on installation, then I open my Maya 2020, it reports this error:
The Houdini Engine for Maya plugin could not be initialized.
The path to libHAPIL is invalid. Please double-check the value in Houdini Engine>Preference.
The HFS location I provided is C:/Program Files/Side Effects Software/Houdini19.5.493
and libHAPIL location is C:/Program Files/Side Effects Software/Houdini19.5.493/bin/libHAPIL.dll
Is the problem related to the path format? Maybe there are some more setup steps I missed? Thank you!!
How did you install Houdini and the plugin? Did you use the legacy installer, or the launcher?
Hi, thank you for your reply!
I used the launcher to install everything, Houdini 19.5.493 itself and also the plugin. I noticed that it first checks the $HFS variable in the code so I manually added the path to environment variable and it is able to load the plugin now. So somehow the paths I put in the houdini engine preference are not recogonized.
Thank you, inserting
HFS = C:/Program Files/Side Effects Software/Houdini19.5.493
in the maya .env made it work again.
Edit:
I think Sidefx changed something in the installation. Now there is a space between houdini and 19.5.493. So the path now has to look like this
HFS = C:/Program Files/Side Effects Software/Houdini 19.5.493
Edited by sbobcat - Feb. 12, 2024 10:03:33
shen25748
Hello could you be more specific how to modify this??
dragonyhr66
shen25748
It's been a while, but since I just ran into the same issue, I thought I'd answer for the benefit of those who come later. You need to edit the file maya.env, which is described here: https://help.autodesk.com/view/MAYAUL/2024/ENU/?guid=GUID-8EFB1AC1-ED7D-4099-9EEE-624097872C04 [help.autodesk.com]
Mine was completely empty, so I just added the line, as described by Bobcat:
HFS = D:\Production\SideFX\Houdini 20.0.625
That's obviously the path to my Houdini install—you'd change it to wherever yours is. Once I'd made that change, Maya loaded the plug-in without complaint.
Edited by BryanRay - March 20, 2024 14:39:29
BryanRay
dragonyhr66
shen25748
BryanRay
dragonyhr66
shen25748
Thanks mate you save my life!
