Is Mapbox SOP working for people?
   1173   1   2
So I wanted to check out this node...
But I keep getting errors. This is on 19.5.534.
- I setup account at Mapbox
- On my accounts page I copied the default access token
- Pasted the default access token into Mapbox API Key
- In the node parameters which default to 0,0,0 I select 'Look Up'
- A window pops up that says 'MapBox - Selection Location' and in the content 'ERR_FILE_NOT_FOUND'
Thank you!
LP
Hi, Same as you. the Select location don't work.
If i enter Lat Lon Zoom manualy, my terrain appear.
So, it's the Look up windows wich seems to have issue.
Any help ?
