RBD_constraints issue
   795   1   1
Hello Everyone, hope you all doing Great.
I have a very simple scene made of 3 walls that i want to simulate.. i have fractured each wall separately using Boolean Fracture
then i have created the constraints for each wall
the problem is in the DOP network one of the walls will completely ignore the constraints and fall even though it's constraint didn't break .. and when i change the order of the merge of each fractured wall output, the other 2 will ignore the constraints and the other one will not
i have no idea what is causing this..
here's the Hip file if any one wants to take a look at.
Thank you so much
Edited by minavaseily - March 24, 2023 05:31:00
walls_dest_share.hip (751.9 KB)
i have found the problem, I have forgot to switch the name attribute in the Boolean fracture from overwrite to append which ended up with duplicates values for the name attribute. setting it to Append giving the pieces unique name and that solves everything.
