Retime USD
   5077   16   4
How would one go about retiming a usd file?
I've referenced a usd and then tried to use a timeshift lop but it doesn't seem to have any effect.
The usd has some animated geometry (animated xforms not deforming geo) and I want it to play for a certain number of frames before freezing for the rest of the shot.
The timeshift LOP should be able to do what you want here. Attached is an example showing how to use it to speed up the crag animation. Make sure that you set the timeshift LOP parameters to target all the prims and attributes for which you want to retime the animation.
retimed_crag.hip (97.3 KB)
It seems like the primpattern parameter is a little finicky and I just wasn't putting in a path it liked.
For crag: "/crag/*" doesn't work but "/crag/geo/*" does.
In my case only "*" works. I tried targeting a particular scope in my component ("/componentname/geo/*") and it does nothing. I've probably just made a bad component.
For future reference: Is it possible to use this to retime particles or deforming geo too? A quick test seems to indicate no but I could just be missing something or doing something wrong.
Edited by pixelninja - March 27, 2023 17:31:50
/crag/* is only targeting the geo and mat scopes. /crag/** in that case would target any levels of hierarchy.
https://www.sidefx.com/docs/houdini/solaris/pattern.html [www.sidefx.com]
Ah amazing, that's really helpful.
I made some incorrect assumptions about the pattern matching. A good reminder to read the docs closer.
Just in case anyone else runs into the same issue I figured out why my particle test didn't work.
I had packed the particles so that I could bring it into lops alongside other geo in the sop import with prim path attributes.
This caused the particle geo to be converted to a usd instance. Meaning that in order to retime it you'd need a retime instances lop instead of a timeshift.
You could also have set the SOP Import to import packed prims as "Create Xforms: instead of "Create NativeInstance". Retime instances is more useful for cases where you actually have multiple instances of the same animated geometry, and you want to provide some variation in the playback speed/offset across a set of instances. The Timeshift LOP provides more control, and if you've just got one "instance" you don't lose any performance or memory efficiency by simply not using instancing.
Definitely. Though in this case I was attempting to bring in mixed geometry, so some packed geo actually were instances.
Probably better to just split them out into separate imports in this case.
Hello, Is there a way to retime cameras too?
I've tried targeting a geo and cam, but only the geo seems to work, I might be doing something wrong.
Edited by fadjo - April 14, 2023 12:49:54
lop_timeshift_test.hip (382.0 KB)
That should work, and you can see that adding a cache LOP gets the camera to reflect the retime - this looks like a bug.
In the meantime, if you want to retime any particular prim instead of the entire stage, you can do it fairly easily with a Python LOP - you just need to make sure there are timesamples available on the attribs that need retiming.
lop_timeshift_test.hip (389.5 KB)
Thanks Nick and Mark, I tried a ridiculously slow and super dumb thought exercise with for loop lops that at least worked, then saw this thread and your answers and tried to mod Nicks code to usd retime by attrib. Any recommendations to make it better/more correct?
I would drive the 'timey' attribute by distance or something. And so I think I excluded 'timey' from being also updated in the python. It still gets slow on lots of stuff. Could I vex it for speed?
Edited by GrahamDClark - April 18, 2023 02:44:59
Screenshot 2023-04-18 010007.png (1.2 MB)
timeshiftByAttribRadius.hipnc (118.5 KB)
Screenshot 2023-04-18 023718.png (1.3 MB)
lop_timeshift_test_by_attrib.hipnc (432.4 KB)
fadjo
Actually, I spoke too soon. After talking to Mark and looking into the hip file a bit more in depth, the timeshift is doing what it's supposed to, and only offsetting the time samples on the specified prims. The problem is the transform for the camera is coming from its /camparent which has been omitted from the list of prims to retime. If you add /camto the timeshift LOP's primitives parm, you'll have the camera motion retimed as expected.
Now, looking at the viewport after the timeshift LOP, it looks like the whole stage is being retimed - however the time samples that are being displayed are for different frames - but having only 1 time sample on the stage at the current time, that's what's being displayed.
Writing the sequence of frames to disk will fix that, or, dropping a cache LOP either before or after the timeshift LOP will ensure the correct thing is being displayed in the viewport since more timesamples are available.
GrahamDClark
The only thing I'd change in your code is the
if timey is not None:
   frame = curFrame * node.evalParm("timescale") - timey
and replace it with
frame = curFrame * node.evalParm("timescale") - (timey if timey != None else node.evalParm("frameoffset"))
this is to ensure you reuse the frame offset from the parm if timey doesn't exist on the current prim as opposed to whatever the last prim with a valid timey attrib set your frame variable to.
Otherwise, if you know you have all the timesamples you care about, you could make the python LOP non-time dependent by grabbing all the timesamples on the animated attribs, deleting them from the attrib and re-applying them with the time offset - this would avoid having you invoke hou.frame(). This is only really an option if the input node isn't time-dependent - you'd get a bigger initial hit but then scrubbing the timeline would be free since the python LOP won't be time-dependent and its result cached.
GrahamDClark
You could use VEX, using
usd_attrib(<stage>, string primpath, string name, float timecode);
but you'd need to cater for every attrib type and I'm not entirely sure it'd be any faster.
thank you! will stick with the python and try your suggestion to avoid hou.frame() (and better as i mod it for files).
Hello evryone.
I have been running into issues with trying to retime instances and i figured I`d ask here.
the problem is that when i try to retime the instances, they only play when they are at timespeed 1 total.
WHen i try to recreate with a simpler geo and animation it sometimes works .
i`d realy apreciate it if someone could help me out.
error_timescale_ntanghe.zip (535.7 KB)
The problem you're having is the timescale applied to animation that happens at frames so large will shift the animation greatly.
For example, if you have animation between frames 1000 and 1200, with a timescale of 0.5, the animation will now exist between frames 500 and 600. So you need to apply a frame offset to compensate for that.
The way the retime works is it first applies the timescale to the animation and then adds the frame offset.
In your hipfile, if you set the frame range start to 1 and scroll the timeline from 1 to 1500, you'll see all the retimed instances flap their wings, however, nowhere within your current frame range.
You have animation from frame 1008 to frame 1048, if you want the timescaled retime to happen within that frame range, set the global frame offset to 0 and the global time scale to 1 to simplify things and change the wrangle to:
f@timescale = rand(@ptnum);
f@rand = -1008 + (1008 * f@timescale);
Hello so as mentioned in chat earlyer having a value clip whould also solve the problem i was having. I cant seem to be able to set it up correctly though.
No matter what i do it holds the last frame.
valueclip_error-ntanghe.zip (633.3 KB)
