Suppress network change when selecting objects in subnets?
   1005   0   0
Hi, it has been a while since I dropped in the forums.
I'm making an HDA that has an object subnet with editable contents. I want the main HDA interface to make changes to the selected nodes inside that subnet but when you select any or multiple of those nodes Houdini changes the network to focus on one of the selected nodes.
Is there any way to suppress that behavior for just that HDA? I am aware that you can pin the networks but this is not ideal since you would have to unpin them to do return to your preferred behavior for other operations.
I've looked into using select scripts to change the network back to the users original network but they run on each selected node, so isn't really ideal.
Jeff Willette
Freelance TD
