How can I randomize rotation to individual points.
   2302   3   2
How can I randomize rotation on the Y axis for each individual point using orientation attribute in Attribrandomize?
Thank you all!
Edited by havana - March 31, 2023 16:35:32
Try using Attribute Adjust Vector SOP to handle this. Depending on how your source object is aligned, you'd want to adjust either the N attribute or the up attribute.
If you did want to randomize orientation fully, you'd want to write to `orient`, not `orientation`.
MOPs Randomize [github.com] is also a pretty user-friendly way of randomizing orientations, among other things. It'll work on template points as well as existing packed primitives.
Problem solved! Thanks to this thread: How to rotate on scattered geos on Y axis (@N with @up ??)
Edited by havana - March 31, 2023 18:33:27
toadstorm
Somehow this only works with orientation. orient point towards the Z axis.
