Hello, I am noticing that imported .stl files are not loading in my new H 19.5.569 when they perfectly did in previous versions.
I did test with a few stl files I have in my pipeline and they don't open in 19.5.569 and they open in 19.5.534.
Any idea how to circumvent this issue ?
Thank you !
Tanguy
Did .stl import changed since last few versions ?
1716 9 1- tanguybc
- 42 posts
- tanguybc
- 42 posts
- BabaJ
- 2129 posts
- tanguybc
- 42 posts
So I did some test and I taught it was solely a poly count threshold but looks like not.
In 403 I don’t think you would see any of this behavior. I am working with .stl in Houdini for years and always been able to load whatever I fed ah H. The behavior changed with 19.5.569
Right now I seem to fine below 1.230.000 polys
But I got a 1223404 polys file which failing and a 1250980 passing so not entirely sure, BUT overall the behavior is following a poly count rule no matter what. and the last 2 files I mentioned are quite neighbors in term of poly count, I am gonna investigate further. For now I will do my stl ingest >> vdb >> before in 534 and resume pipeline operation on 569 for the time being
Edited by tanguybc - April 30, 2023 12:08:41
- BabaJ
- 2129 posts
- tanguybc
- 42 posts
- tanguybc
- 42 posts
- BabaJ
- 2129 posts
- tanguybc
- 42 posts
- tanguybc
- 42 posts
