How to select a point in the viewer at same position?
   1001   3   0
I use edit sop to edit points.
If the 2 points have the same position, I can't tell which point is being selected until move it.
But I don't want to alter the position of the point that I don't want to select.
How to select one or another without moving it?
Edited by jerry7 - May 3, 2023 22:21:37
select point.png (98.0 KB)
You can use the rigpose node instead of edit and set it to world position. For any other situation I would still use the edit though
Edited by willh - May 4, 2023 02:45:55
@jerry7
you can click select the two points (only one will be selected). then move it and check if it's the desired one. If not, undo your movement and ctrl+shift drag select on the two points. now you have the other one selected.
Cheers
CYTE
Edited by CYTE - May 4, 2023 03:10:45
Thanks for the upper tips!
