find number of voxels
   1716   4   0
Is there a way to turn the number of voxels in a vdb into something accessible via vex? Short story long, I'm trying to test to see if an object can be turned into a vdb, and if it produces no voxels. Then use a different technique.
thanks
you can probably use volumeres() [www.sidefx.com] Hscript function
or volumeres() [www.sidefx.com] VEX function
to see if any of the dimensions is 0, in which case the volume primitive has probably no voxels
you can probably also use Bound SOP, if it returns all points at origin, the input has probably no voxels
FX Supervisor
Method Studios, NY
Thanks Tomas! Great ideas. Bound is probably easiest for what I'm doing,
thanks again.
There's a primintrinsic called activevoxelcount.
Jobless
Thank you Soothsayer, That's another great option. For anyone looking into this in the future, the vex is, assuming your volume is plugged into the second input:
i@vCount = primintrinsic(1, "activevoxelcount", 0);
Edited by chris wells - May 8, 2023 11:38:13
