Hi All,
I have what I hope is an easy one ... I want to change the value of the Solid Type Parameter Dropdown via Tops based on the @pdg_index.
Can anyone tell me how to do this ?
Changing a dropdown menu paramter via tops ?
1043 1 0- dunnieboy
- 11 posts
- tpetrick
- 600 posts
You can right-mouse click on the Solid Type and go to Expression -> Edit Expression, and then put @pdg_index into the expression editor. I've attached a simple example that generates five work items and imports a different platonic solid type from SOPs for each item. The example was created in H19.5, but the same thing should work in any version.
