PDG crashing with nuke server
   1223   1   0
I'm running Nuke command inside houidini PDG to execute nuke operations, I've approximatly 25000 workitems.
Problem: It getting crashed after 500 workitems everytime.
I guess is RAM is getting full and crashing with error, I need to resubmit the chain again after every 500index. any suggestion on solving this problem please
" No connection could be made because the target machine actively refused it"
this is the error I'm getting after 500 workitems. on the python node where I use to execute writenode command in Nuke
Thank You
Hello, I would like to learn how to use nuke server。Can you explain how this is used? I encountered an error when opening the help file and running it
