An Issue with Houdini Engine Curve Node and HDA
   2083   1   2
Description:
As I was learning to use HDA to create roads in Houdini, I utilized the Houdini Engine Curve and an HDA to generate the road model. Initially, everything went smoothly, but now I've encountered an issue. When I first start editing the curve, the model generated by the HDA updates in real-time. However, after performing a few operations, the HDA stops updating, and I have to manually select "Rebuild" for the asset to update. This disrupts my workflow. I'm wondering if there's a solution to this problem. I would greatly appreciate any guidance or insights you can provide.
Versions used:
Houdini - 19.5.493
Unity - 2022.2.15
Thank you in advance for your assistance.
curve_roads.hda (16.9 KB)
20230517_023910.mp4 (457.1 KB)
Hi.
You might have some guidelines here [www.sidefx.com] if you still require fix.
