Determining where a cook command comes from?
   Views 1262   Replies 0   Subscribers 0
I am trying to find a way to determine if a node cook is being initiated on the node itself vs requested from a downstream node. I have a feeling that there is something to do with event handlers, but can't seem to figure out how to get them to trigger properly. I am trying to either:
  1. Flip a switch TOP based on the cooking request source
  2. Adjust how a Python Processor works based on the result request source
I feel like there should be a way to glean the information, but just can't seem to find it. I do have something in place if I cannot automate this, but I REALLY want to automate this so I can have it in my toolbox for the future.
Here is the onGenerate() that I am using in a python processor currently:
import json, hou, os
def writeWorkItemJSONs(JSONPath, context):
    try:
        os.mkdir(JSONPath)
    except Exception as e:
        pass
    for upstream_item in upstream_items:
        jsonWorkItem = context.serializeWorkItemToJSON(upstream_item)
        with open(f'{JSONPath}/WorkItem.{upstream_item.index}.json', "w") as f:
            f.write(jsonWorkItem)
        new_item = item_holder.addWorkItem(parent=upstream_item, inProcess=True)
def loadWorkItemJSONs(JSONPath):
    for file in os.listdir(JSONPath):
        new_item = item_holder.addWorkItemFromJSONFile(f'{JSONPath}/{file}')
context = self.context
hipPath = "/".join(hou.hipFile.path().split('/')[:-1])
JSONPath = hipPath + '/workItem_JSON'
try:
    if len(os.listdir(JSONPath)) > 0:
    else:
except Exeption as e:
This works about halfway to what I need. When I cook without the outputs present or without the JSON files for the work items, it processes writeWorkItemJSONs and has the work item dependencies going all the way up the chain. If the JSON files are present and the outputs are there, the work items are created from the JSONs and lack the dependencies, but the input node is still cooked. I need a way to prevent the nodes above this processor from cooking in the loadWorkItemJSONs() function. I saw that the processor is supposed to have an onPreCook() method I can invoke (here [www.sidefx.com]), but the documentation is a little light on details.
I also found that there is a filter on the pdg.graphContext that is supposed to affect the graph cooking, but I'm trying to figure out how to use it and where it would be best to do so. I have some ideas, and will report back if anything comes of them.
Edited by Adam F - May 19, 2023 16:45:38
