How to set default value for transform parameter?
   1066   2   0
I noticed that the Light Object has a non-trivial default transform parameter value.
How to make it in my Object HDA?
Edited by jerry7 - May 20, 2023 19:11:26
similarly to storing the literal default value, just change from Literal to Hscript in this case, or optionally Python if you want it to default to Python expression
FX Supervisor
Method Studios, NY
I saw the Light Object HDA's transform parameters are greyed out and can't be edited.
How does it set the expression?
