libpng warning
   2217   3   1
Houdini Console:
libpng warning: iCCP: known incorrect sRGB profile
hou to solve the problem
help me
same question
The warning is coming from the PNG library. It should be safe to ignore, however if you want to remove this warning, you will need to remove the offending profile. If you have ImageMagick, you can run: mogrify my.png
johnmather
Every time I switch to the Chinese input method, this error occurs, it's really annoying
