Houdini VDB to UE5.2 not looking correct
   Views 2587   Replies 1   Subscribers 1
I have been able to get a VDB imported with the Montreal plugin and I can see the animations however the density and overall look is poor. I used a reference embergen VDB from their webpage as shown in the demos for the plugin and it looks as expected. I tried exporting a Houdini sim using a VDB from the file cache and the ROP. The main problem being that the density never feels dense enough to even pick up lighting. I even used a volume slice for inspecting values and made sure my Houdini sim had similar values for Density, Flame and Temperature compared to the slices from the Embergen reference. I basically tried to get the attributes looking close, I’m wondering if anyone knows what could be causing different results. Basically density values no matter how nutty the multiplier will get me a volume that is just a faint ambient color with no volume shadows, the whole VDB renders as a flat solid color.
- “spooky action at a distance”. Albert Einstein
I managed to find the problem, looks like I need to create min max bounds attributes on each VDB primitive. Simple fix is plug the sim into a box then write the point min max using an attribute vop / wrangle on a second input.
