Remesh 2.0 - possible bug?
   1032   2   0
Hi guys,
Looks like the new remesh sop doesn't carry the integer attributes of its input.
I does carries the vectors and floats, this is only an issue with integers(i havent tested rest of the types), I have attached a sample scene here.
"cluster" is my int attribute, you can see it is having unique value per piece before remesh and it becomes 0 after the remesh. however the old remesh does this well.
I have also included a workaround to use the remesh2.0 incase if anyone wants.
Anybody have faced the same problem?
remesh_integer_attribs.mp4 (3.9 MB)
Screenshot 2023-06-09 185549.png (67.5 KB)
remesh_2.0_issue.hiplc (283.6 KB)
Mohan Pugaz
movfx
I suppose you could call that a bug, but if you promote cluster to primitives, the Remesh 2.0 does accurately forward the attribute through the network. It also works if you check Use Input Points only, but that produces a bad remesh.
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
Hi Enivob,
Thanks for your inputs
Mohan Pugaz
movfx
