Flipping Normals
   4774   12   1
While progressing with the data received in Unreal Engine, I encounter situations where certain normal directions are flipped, as shown in the image. If I want to procedurally flip only the inverted faces, what should I do?
스크린샷 2023-07-04 203801.png (422.7 KB)
PolyDoctor's "Correct Winding of Polygons to Majority in their Manifold Patch" is one way to do it.
Polydoctor seems to operate only on the flipped faces within connected polygons. It doesn't seem to affect polygons that are detached or separate.
To elaborate further, after going through several processes, when I merge convert lines and perform a polygon fill, occasionally I encounter flipped normals. What should I do to prevent flipped normals from occurring?
Do prims that you're generating always lie on a flat plane, like on the screenshot?
Edited by ajz3d - July 5, 2023 08:56:20
ajz3d
Due to obtaining surface information from the low hills of the landscape, slopes can occur in some cases.
Edited by gallerykim - July 5, 2023 21:28:21
If this is the case, then perhaps it will be enough to reverse all primitives which have normals within a specific spread angle from the (0, -1, 0) vector? It should work for this kind of data.
Edited by ajz3d - July 6, 2023 06:30:17
normal_spread_angle.hipnc (166.4 KB)
ajz3d
Do I need to modify @N to change the normal vector?
When instructed to multiply by -1 when @N.y < 0, in the spread sheet, the N value became positive, but the actual normal did not flip.
gallerykim
Depends.
  • If you have no existing vertex normals and it is only primitive winding that is wrong, then obviously no.
  • If you have existing vertex normals, then regardless of primitive winding you will also need to reverse vertex normals.
It would be best if you could post a sample scene.
Maybe it's a viewport bug? Or perhaps you're multiplying only one vector component instead of negating the full vector?
fix_reversed_vx_N.hipnc.zip (31.3 KB)
Thank you for providing the sample. I've tried incorporating a portion of my scene into the sample file, but I'm still encountering issues with the normals that need to be resolved before performing the final extrude operation.
fix_reversed_vx_N_stash.zip (144.9 KB)
I added two Reverse SOPs (one per method) to the network that are reversing the candidate group, and now PolyExtrude returns correct result.
There were ill-formed primitives in the input geometry, so I cleaned them up by recreating primitives from their edges. This might not be a perfect solution, but it works on geometry data you provided.
fix_reversed_vx_N_stash.hipnc.zip (46.2 KB)
The issue has been resolved cleanly.
Thank you very much!!
You're welcome.
