Hi there.
For the past couple of months, the labs ruler fails to load because of this error :
File "labs::ruler", line 13, in <module>
File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.640/houdini/python3.7libs\houpythonportion\ui.py", line 1119, in decorator
return func(*args, **kwargs)
File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.640/houdini/python3.7libs\hou.py", line 75027, in setCurrentState
return _hou.SceneViewer_setCurrentState(self, *args, **kwargs)
hou.OperationFailed: The attempted operation failed.
Failed setting state named "labs::ruler".
And the quickMaterial node spawns this error.
Warning: Problem while synchronizing child node:
Warning: Skipping unrecognized parameter "diffuse_folder_15".
Skipping unrecognized parameter "folder7".
Skipping unrecognized parameter "folder4".
Skipping unrecognized parameter "folder12".
Skipping unrecognized parameter "shading_16".
Skipping unrecognized parameter "folder14".
Skipping unrecognized parameter "folder9".
Skipping unrecognized parameter "folder13".
Am I the only one getting these? I've tried various new houdini installs and labs installs but can't get either resolved.
-seneca
Labs Ruler / QuickMaterial Errors?
1323 4 1- indigosm
- 49 posts
- sjc000com
- 4 posts
- indigosm
- 49 posts
- calabrese20
- 1 posts
- indigosm
- 49 posts
calabrese20awesome thank you! i'll definitely try this if (when) it happens again. i've uninstalled and installed so many different versions of houdini / labs that i eventually got it fixed.. i assume part of the problem is that there's like at least 3 different ways to install labs, and i think one or some were corrupting it......
To fix go to the "Viewer State Browser" tab and load it directly in your workspace its in the labs install location in the viewer states folder
- sidefx installer of just installing labs
- sidefx installer of installing houdini and labs is included
- installing labs from the labs tab in the houdini app
- isn't there a houdini 'update' in the sidefx installer too? i forget
Edited by indigosm - May 17, 2024 14:32:21
