custom crowd trigger node
   1193   3   2
I'm interested in creating my own custom crowd trigger node as the current node is somewhat limited in options. I know I can use the VEX mode to get more detailed, but I was hoping to setup something like the pop vop but for setting triggers. In the manual it says: "A user-defined asset can also be used as a trigger if it has a triggerattrib parameter specifying the name of the point attribute that contains its trigger value." But when I setup this parameter, it still doesn't seem to work, with the error "cant find trigger name" Any ideas?
Thanks, Karl
Just use VEX mode. All you have to do is set i@trigger on the point.
// setting i@trigger to 1 will enable
// setting i@trigger to 0 will disable
i@trigger = -1;
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
While it is true I could just use the VEX mode, I see in the manual that there is a way to make your own. So now I want to! A common frustration with the Houdini manual, I'm sure.
Edited by Karl Richter - July 12, 2023 12:21:58
Can you attach an example of your HDA? This approach should work for letting a custom HDA act as a trigger
