i want to transfer a attriute and make sure that after several frames i will have it. trying the tutorial
https://voxelpixel.xyz/2020/04/21/houdini-using-a-solver-to-persist-attribute-transfer/#:~:text=We%20do%20the%20attribute%20transfer%20inside%20a%20solver,to%20the%20next%20iteration%20to%20be%20painted%20again.
but nothing moves inside the solver
how can i use the solver to keep the attibute?
keep an attibute with a solver after is been transfer
946 3 0- pelos
- 621 posts
- animatrix_
- 4731 posts
I think your inputs are mixed. Swapping them works.
- pelos
- 621 posts
- animatrix_
- 4731 posts
Oh yes if you want that you have to copy all attributes except P from previous frame node like this and then do the attrib transfer after:
It's a custom Python Qt extension that I explain here around (30 mins mark):
pelos
(also how you did to have the network on top of the viewport? that's cool )
