houdini 19.5 issue - stacking Set Variant nodes
   934   1   0
We just switched to 19.5 and we noticed when choosing a variant by right click (in scene graph or right clink in the viewport) on the asset with variants, and then choosing another variant houdini stacks Set variant nodes for each change of variant.
This behavior is different in houdini 19.0.567 where it would create only one set variant node and then change the variant of that node every time you switch the variant with right click again.
Is this controllable by settings or is it a bug or rather intended behavior?
Thanks,
Martin
Edited by martinium - July 19, 2023 16:42:55
This is a bug in 19.5 (is being fixed and tested at the moment).
