hou.ui.display , ask me again please !!!!
   1268   1   1
I wrote this code :
sbtn = hou.ui.displayCustomConfirmation('Do you want it ', buttons=('Yes','No'), title='ActionZ')
if sbtn==0:
    print('aaa')
if sbtn==1:
    print('bbb')
The window came with title, buttons and a toggle labelled 'Don't ask me again'
Of course I switched on the toggle to test and now there is no popup anymore, even after a relaunch.
How Can I get my window back ?
Is it possible to eliminate this toggle ?
Thanks for your help !
Edited by vbk!!! - July 31, 2023 10:44:47
http://vimeo.com/vbkstudio [vimeo.com]
The `displayCustomConfirmation()` function has a `suppress` parameter, which is set to `hou.confirmType.OverwriteFile` by default.
So try toggling "Warn Before Owerwriting Files" in Edit > Preferences > Warning Dialogs.
To avoid the toggle, instead of `displayCustomConfirmation()`, try `displayMessage()` with the same arguments.
