How is "unreal_bake_actor" attribute used?
   1580   2   1
I'd like to set the name of the Actor that is created on baking a HDA. However, when the HDA creates instances using the `unreal_instance` attribute, the `unreal_output_name` attribute does not seem to apply to the Actor's name. I thought perhaps the `unreal_bake_actor` attribute would work instead, but setting it does not seem to do anything.
I found out you can use unreal_bake_actor to determine the name of Actors with InstancedStaticMeshComponents if you also set the unreal_level_path, i.e. baking to a different level.
Seems like a bug.
Hi did you ever get this to work?
I'm having the same problem and can't get a baked blueprint to generate with a specific name
MC
