In geometry sheet it should looks like for each element if it works.
the api is
FHoudiniApi::SetAttributeFloatArrayData(
NodeId,
ParentId,
TCHAR_TO_ANSI(*AttribName),
&AttribInfo,
Array.GetData(),
Array.Num(),
SizeFixedArray.GetData(),
0,
SizesFixedArray.Num());
for example I have two points, and I want to create an empty float array attribute for them. I just set AttribInfo.count to 2, tuple size to 1. totalArrayElements to 0. SizeFixedArray to {0,0}. Array is Empty. Is it rigth? Or should I set SizeFixedArray empty? Or just create the attribute but do not set? Or it is not valid to create an empty array attrib?
Hapi Failed when SetAttributeFloatArrayData with empty array
1601 0 0- evianaive
- 10 posts
