USD Character Import Problem
   Views 2168   Replies 7   Subscribers 1
Hi
If I import a USD Character using the USD Character Importer in a Create SOP in LOP, the performance of
the animation is very slow compared if I import it in OBJ context and display there.
Another thing, I can't get rid of the rest pose, displayed as points, these points aren't displayed if I import in obj context.
What am I doing wrong?
Edited by tomtm - Aug. 12, 2023 05:24:50
Have you tried sublayering or referencing the usd into lops, or is it just a rig that is animated in sops?
jsmack
It's a .usd File imported in the LOP Network in a SOP Create.
But if I import the same file in in the .obj context it's playing in realtime, then this point cage isn't visible.
tomtm
jsmack
If it's a usd file, then a sop create not the typical way to import that. Reference it directly onto the scene graph in LOPs with a reference node.
jsmack
tomtm
jsmack
I uploaded a hiplc, I tried it also with AssetReference, but it's much slower in GL View compared if I import via USD Character Loader in the obj. context. Oh my god, is this all complicated :-)
What is the way to import USD Characters properly?
Edited by tomtm - Aug. 14, 2023 18:11:33
USD_Character_Test.zip (6.8 MB)
tomtm
I just hit the equals key and picked the usd from the file dialog, then you can choose which way to import it. I picked reference but I don't think it matters unless you have specific things you need to do after importing. Yeah it's slower than the sop viewport, I think there must be something slow going on in the HoudiniGL viewport like computing tangents or something. The Storm viewport doesn't have that problem.
jsmack
tomtm
thanks for answering.
The equals key? Where do you hit this and then there is a dialog? Sorry, I don't get it. :-)
The = key on the keyboard is the hotkey for importing geometry. In LOPS it will import usd into the stage, but since there are multiple ways to load things in USD, it presents a dialog to choose which one to use.
You can also use the tab menu to place a reference node or sublayer node directly.
