Labs Flowmap Visualize Viewport Shader Doesn't Work
   2158   2   1
Hey guys (HIP attached), when I enable viewport shader option AND turn ON the viewport option "Display materials on objects", I get this error to the console (not sure how to debug it):
vec3, vec3, vec3, vec3, vec3, float, float, float, float, float, float, float, float, vec4, vec3, float, float, int, int);"
/obj/geo1/flowmap_visualize1/shopnet1/shop_flowmap_shader1: Linking failed.
LINK[/obj/geo1/flowmap_visualize2/shopnet1/shop_flowmap_shader1]:
Fragment info
0(216) : error C3002: call to undefined function "void HOUassignOutputs(vec3, vec3, vec3, vec3, vec3, vec3, float, float, float, float, float, float, float, float, vec4, vec3, float, float, int, int);"
/obj/geo1/flowmap_visualize2/shopnet1/shop_flowmap_shader1: Linking failed.
I've recreated almost the same setup as in the docs:
However, only the vertex color option works on my end:
Expected result:
I assumed that this is because of the
$SIDEFXLABS/misc/flowmap/flowmap_visualize.jpg
path and tried to change it to
opdef:../..?flowmap_visualize.jpg
but it doesn't work. The reason I tried this is because I saw in a couple of videos that this option is used instead of embedded image 🙂
I've also tried to replace SHOP with MAT context (changing contents of "flowmap_visualize1" node) but didn't work out (maybe missed something).
Thank you for taking a look.
Edited by AnimGraphLab - Sept. 1, 2023 03:49:38
flowmap_viz_bug.hiplc (289.4 KB)
Generalist. Transforming still images to 3D animation 🔮
Socials: https://linktr.ee/AnimGraphLab [linktr.ee]
Adding “vec3 coat_color, float sheen_intensity, float sheen_rough, vec3 sheen_color”
into HOUassignOutputs after “coat_rough” can fix the issue.
It has been fixed a couple of months ago
