Point VOP Noise
   1712   4   2
Hi, How do I make a noise like this with vop?
Here is a quick attempt with HIP file. The setup calculates an angle for each point and also looks at its distance from the center. Both of these are used as inputs for noises. The two noises are multiplied together to limit the length of each "line".
Before feeding into each final noise, a noise is added to the angle and the length in order to make the lines crooked.
Edited by Digipiction - Sept. 14, 2023 05:34:04
CircleNoise.hip (346.4 KB)
amazing. I share my project. just want to add circle noise to the turbulent noise. the noise starts from the center exactly like in this picture but for a circle.
Noise.hip (243.8 KB)
Here's the noise radiating out from the center.
NoiseRadial.hip (285.8 KB)
appraciate you.
