Hello
i was just wondering if there is an easy way after you make a reference copy of a specific node, to move it to another context without breaking all the relative references.
for example i make a unified noise inside a vop in a solver with all of its parameters linked to a null controller in obj.
i make a reference copy of that unified noise and i'd like to paste it in a vop outside of the solver maintaining all the relative references to the null controller.
Move reference copy node
1443 5 2-
- papsphilip
- 385 posts
- SWest
- 313 posts
Try dragging your reference node to the shelf. Then edit it and look for a relative path. After that you can use search and replace to either make every path absolute. If you want a relative path you need to determine from where it should go. Apply the changes and now drag and drop the node from the shelf to the desired location.
Cheers!
Cheers!
- CYTE
- 703 posts
This Houdini Toolbox, comes with an extra entry to the right-click menu that adds an absolute reference copy.
Houdini-Toolbox [github.com]
Cheers
CYTE
Cheers
CYTE
- papsphilip
- 385 posts
CYTE
Cheers
CYTE
going for the packages installation but after restarting Houdini i cant find the right click menu option you are talking about.
- CYTE
- 703 posts
- papsphilip
- 385 posts
