Using Vellum As a Post Process for RBD Sim
   735   1   0
Hi!
I did this RBD sim that moves packed primitive leaves along the ground when a car drives by:
Is there an established workflow that would allow me to use the position and orientation attributes of these points to now drive the position and orientation of vellum objects in a vellum simulation on unpacked versions of this geo (so that they have the same general motion but have additional vellum deformation on top of them)?
Anson
Edited by AnsonSavage - Oct. 24, 2023 19:55:12
Assuming you don't have changing topology, unpack the rbd objects and try using a soft Pin to Target constraint and check on the option for "Match Animation".
