Slide an Object on Ground Plane
   1224   1   0
I am following a rigidbody tutorial, and I cannot get my cube to slide across the ground plane. I turned the Bounce and friction to 0 on the ground plane, and the cube would just fall and stop. It does not move once it hits the plane.
if the Cube only has gravity applied (which would be a force of (0, -9.8, 0) ) ...then why would it move in any other direction?
there is likely a step in whatever tutorial you're following that adds some force that you've missed.
hope that helps.
Training Lead
www.sidefx.com
