RBD Spherical Glass to Maya ... Cracks are showing.
   576   0   0
So I did a whole workflow on Houdini for a fracture in a spherical glass.
This is the workflow I did.
This is the current problem at hand after a fellow advised to fix Normals from Houdini and export to Alembic instead.
Now I'm left with this.
Quality is better now with the Normals fixed, but the cracks are still showing.
Anyone has a clue how to export the Connected Faces / Disconnected Faces nodes to the Alembic to fix this issue... Or any other solution or workaround would do.
Thanks in advance.
Screenshot 2023-11-07 175628.png (492.3 KB)
