'P', 'Depth', or 'UV' outputs in Karma seem to be broken.
'P' and 'Depth' outputs are well done in 19.5 version, but 'UV' output is not produced in both versions.
Are ray level outputs such as 'P', 'Depth', or 'UV' broken in H20?
1996 8 1- ifree
- 54 posts
- Mark Wallman
- 700 posts
- jsmack
- 8046 posts
- ifree
- 54 posts
- jsmack
- 8046 posts
- ifree
- 54 posts
jsmackifree
Yeh, 'P' is output in the extra vars!
But, how can I output 'Depth'?
It also seems like aov of vector variables is not working in Karma Material Builder.
You should be able to add it in the extra vars, there is a preset called "depth (camera space)"
Thanks, jsmack, it works alright.
But uv is output per polygon rather than per geometry with source type intrinsic, and none with source type primvar.
Edited by ifree - Nov. 28, 2023 21:30:13
- jsmack
- 8046 posts
- ifree
- 54 posts
jsmackThanks, jsmack. Using 'st' solved the problem.ifree
right, the ray:uv output is the face parametric. For the primvar, use 'st' or check your spreadsheet for the actual primvar name.
- ifree
- 54 posts
