Pleading for equivalent of object merge in materials VOP
2128 9 2- sniegockiszymon
- 67 posts
Hello I'm not sure if its right place in forum for propositions of new features but please, add equivalent of "object merge" from sops to materials in solaris (And general in VOP). Scenario like in attached screen breaks my heart. Its very common during creation of procedural materials to use something from the beggining much later, it gets very ugly, very quickly
- wojciech.drzewiecki.dw
- 1 posts
- jomaro
- 102 posts
I think we also need a teleport broadcaster and teleport receiver nodes like in Foundry Mari.
https://learn.foundry.com/mari/Content/reference_guide/nodes/teleport.html [learn.foundry.com]
- Dawid Wizor
- 28 posts
- tamte
- 8832 posts
sniegockiszymonit is not, please submit an RFE [www.sidefx.com]
even though i bet there is already a couple for having Fetch type of node in VOP context, more never hurt especially since it's not been implemented yet
jomarothat sounds unnecessarily complicated, why would you need a dedicated broadcaster node?
Houdini has plenty of good examples in many other contexts, just VOPs are missing it for some reason (Object Merge SOP, Fetch Object, Fetch CHOP, Fetch ROP, Fetch COP, Fetch TOP, Fetch LOP)
so adding Fetch VOP that would expose the same outputs as fetched node would definitely go a long way
Edited by tamte - Nov. 30, 2023 10:01:23
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- jsmack
- 8043 posts
tamte
How do you make a fetch node like that limit you to fetching nodes from with the same subnet though? All of those nodes can fetch from any location, but a material requires its children to be within the same context.
- Tanto
- 463 posts
- jsmack
- 8043 posts
- tamte
- 8832 posts
jsmackyou don't need to fetch from the same subnet
the point is you should be able to fetch from anywhere and the underlying architecture should make sure it correctly references the fetched subnet and if needed includes it as a part of the final shader
or in solaris/usd maybe there can also be a way to reference parts of shading graph using relationships from within other shaders
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- jomaro
- 102 posts
