Creating collections using Python
   Views 1783   Replies 4   Subscribers 1
Hi
I'm trying to create collection using following code:
node = hou.pwd()
stage = node.editableStage()
from pxr import Usd
c = Usd.CollectionAPI(stage.GetPrimAtPath('/collections'), 'dupxo')
inc = c.CreateIncludesRel()
inc.AddTarget('/sphere1')
c.CreateExcludesRel()
c.CreateExpansionRuleAttr(Usd.Tokens.explicitOnly)
c.CreateIncludeRootAttr()
In scene graph, it looks like the collection gets created. But it doesn't appear in primitives field menu. What am I missing in my script?
As a workaround I created a Collection operator to generate empty collection and a Python node to populate collection with data. Then I made an HDA from it. Not an ideal solution, but it works fine.
You python code isn't correctly creating the CollectionAPI. To add a new collection to a prim, you need to call UsdCollecitonAPI::Apply (https://openusd.org/dev/api/class_usd_collection_a_p_i.html#a4c9c1226d01a049864cc0d437900c458). This adds the metadata to the prim indicating that the collection exists. The code you've written just creates some attributes that are associated with a collection with a particular name, but doesn't actually register the collection instance on the prim.
It works. Thanks a bunch.
mtucker
can you give a full example in python? I created a collection but houdini doesn't recognise it in the collections list.
https://www.youtube.com/channel/UC4NQi8wpYUbR9wLolfHrZVA [www.youtube.com]
