Labs File Cache topnet display
   815   1   3
The work item display for topnets in Houdini 20 seemed to have changed since Houdini 19.5.
Right now it is showing the progress for all of the wedges, instead of per job.
Whereas in H19.5 (I don't have an image) it would show you all of the frames, similar to what it shows inside of topnet_cache now.
Am I misremembering and that was not the case? I feel like the older method was a lot more helpful in checking the status of the jobs, and I am always finding myself diving into the view the second image provides to see that. Is this by design, and is there a way to revert back?
Also, the Generate Static button sometimes doesn't work, and I have to press Save in Background and start caching in order for the work items to be generated and visible on the top level of the node.
bump, I find it inconvenient, no way to tell if you cache something or it just stuck there forever
I contribute to the beauty of this world
https://houdininotes.ivanlarinin.com/ [houdininotes.ivanlarinin.com]
