Hi there. I'm noticing that with HE2, I can't automatically refine proxy for my HDA using the same script I had with the preivous version of HE. Not sure what's causing it but my HDA temp mesh recooks everytime but doesn't refine proxy. Any hints? With OnProperty function, I should be able to automatically update input, float parameters coming from HDA but this is not the case.
Im adding the button that supposly has to refine my HDA. I use it in a function called OnPropertyChanged, that in theory, should update as soon as there's any change.
Houdini API in blueprints issue
1509 0 0-
- JoseBringas93
- 15 posts
