Euler angles from two sets of N and up
   Views 1341   Replies 5   Subscribers 0
I have two polys at some odd angle to each other. Each point on either poly has N and up vectors.
From these two sets (source and target) of N and up vectors, in vex, how do I compute the Euler
angles to transform the source poly to the target? What I have doesn't seem to work:
matrix3 m1=ident();
matrix3 m2=ident();
m1=maketransform(vector(point(0,"N",0)),vector(point(0,"up",0))); // source poly
m2=maketransform(vector(point(1,"N",0)),vector(point(1,"up",0))); // target poly
vector4 orient1=quaternion(m1);
vector4 orient2=quaternion(m2);
vector rad=quaterniontoeuler(orient2-orient1,XFORM_XYZ);
// convert to degrees etc
Edited by element33 - Dec. 13, 2023 11:47:45
I feel you have some misunderstanding about what quaternions are.
Correct way to compute the rotation between two rotation matrices is like this. We assume m1 and m2 are both 4x4 matrices:
4@xform = invert(m1) * m2;
vector4 orient = quaternion(set(4@xform));
vector angleaxis = qconvert(orient);
v@axis = normalize(angleaxis);
@angle = degrees(length(angleaxis));
Or:
vector4 orient1 = quaternion(m1);
vector4 orient2 = quaternion(m2);
vector4 orient = qmultiply(orient2, qinvert(orient1)); // Note the order is reversed
You can't just do orient2 - orient1. It would just substract the vector4 element by element, but quaternion rotation is a totally different beast.
Edited by kodra - Dec. 13, 2023 16:01:06
kodra
Thanks, will try this.
kodra
I still can't get it right. Based on my original and your first snippet, I'm trying to get
the 3 Euler angles, but they don't look right. I tried other X, Y, Z combinations, but none works.
4@xform=invert(m1)*m2;
vector4 orient=quaternion(set(4@xform));
vector rad=quaterniontoeuler(orient,0);
v@rot=degrees(rad);
Edited by element33 - Dec. 14, 2023 01:09:23
Check this sample file:
rotation_between.hiplc (82.6 KB)
Screenshot 2023-12-14 160144.png (107.0 KB)
You can also use the cracktransform function:
https://www.sidefx.com/docs/houdini/vex/functions/cracktransform.html [www.sidefx.com]
vector normal0 = normalize ( primuv ( 0, "N", @primnum, 0.5 ) );
vector normal1 = normalize ( primuv ( 1, "N", @primnum, 0.5 ) );
matrix M0 = maketransform ( normalize ( v@up ), normal0 );
matrix M1 = maketransform ( normalize ( v@opinput1_up ), normal1 );
matrix M2 = invert ( M0 ) * M1;
vector angles = cracktransform ( 0, 0, 1, 0, M2 );
v@angles = angles;
