Panoramic camera into stage
   582   1   0
Why the panoramic camera under obj loses its effect when imported into stage.
How do I achieve the same effect in stage, like the one I uploaded?
Is the panorama camera feature separated into a shader nodes, or is XPU not supported for now?
If you see this, please let me know,Thanks!
The projection setting isn't translated to LOPs. This is controlled using a lens shader in Karma. The Karma Physical Lens Shader works with both XPU and CPU render modes.
